Cut river into topography - how do I make its surface lower than the land surface?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
774 Aufrufe, 2 Antworten
I've cut a river (highlighted in blue) into the topography using Subregion. Currently the water is just as high as the land, but I would like to "push" it down so that it's a few metres lower. Is there a way? Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Use a Building Pad and Pad for the water.
Nachricht 3 von 3
als Antwort auf: barthbradley
Thank you!!
