Create Electric Single Line Diagram importing Excel file
jtm2020hyo
jtm2020hyo
Exist any way to create an Electric Single Line Diagram since an imported Excel file in Revit?
I don't understand what you want to do with a Electric Single Line Diagram and Excel. Can you elaborate?
jtm2020hyo
Hi
I do not know if Revit has this options for import any Excel or CSV file then automatically should be create a Single Line Diagram, if not possible, if not, I need some like a scrip or a routine in .NET, I hope someone helps me.
I did an example but in CSV and DWG for explaining my needs in another forum, this works for any class of Single Line Diagram, in my case I need an Electrical diagram. I hope this can be useful.
PD: attached files
related links:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/create-electric-single-line-diagram-...
https://forums.autodesk.com/t5/revit-architecture-forum/create-electric-single-line-diagram-importin...
https://www.theswamp.org/index.php?topic=56014.0
Building Information Modeling (BIM).
