Adjust lighting in a perspective section render
benfranklin0800
benfranklin0800
Hi everyone, I've created a perspective section and gone to render it in ray trace. However, I notice that when you do this, light comes in from where the section cut is almost as if the building itself has been cut. Anyone know anything about how to turn this off? I've attahced a screenshot of what i mean below.
Thanks a lot
L.Maas
That is the case. When you use section boxes or hide objcts they will not be part of the render and thus will not block the lights. There is no setting to change this behavior. For more advane d renders you would need to change over to things like 3ds max.
Louis
Please mention Revit version, especially when uploading Revit files.
