Can you upload "before" and "after" files so people can get more information about it?
@3wood wrote:Can you upload "before" and "after" files so people can get more information about it?
@devitg wrote:
@jtm2020hyo . yes it is possible.Give us , both xls , and dwg where and how to be done.
Good morning.
This took me the entire day, but finally, I did. In theory, should be possible to draw any Single line diagram. if anyone helps me with the lisp I might create a SLD template for everyone.
PD: attached files
related links:
https://www.theswamp.org/index.php?topic=56014.0
@devitg wrote:@jtm2020hyo . Please upload the sample.dwg
I did not notice that was not uploaded.
attached here.
The second example in your drawing seem different from the other 2.
The leftmost of the excel has 2 circuits but the drawing only has 1. Is it correct?
I was searching something like this:
description:
https://forums.autodesk.com/t5/autocad-architecture-forum/new-visio-data-visualizer/td-p/9620472
video:
https://www.youtube.com/watch?v=O2qWMFtyT3s
if someone was developing something similar maybe this add-in help. @devitg @3wood
How did you transfer the data from spreadsheet into the drawing in autocad?
Yes you can GET and PUT cells from a excel spreadsheet, using Vlisp, likewise Excel can talk to Acad using a macro.
A good starting point is getexcel.lsp.
If you google you will find extensive answers to your question. If its a task you want start a new post as the request may have been already answered.
