copying one view template between models
Message 1 of 72
is there a way to copy just one view template between revit jobs or other thing rather than just taking them all?
Like a  add on or something?
Replies (71)
Message 2 of 72
you could do a save as and then delete all but the template you want to carry over then in the manage tab of the project where you want the template you can transfer project standards and just choose the templates.... hey presto
Message 3 of 72
You can transfer View template from project to another One. Select your current project and open the other one with View Template. From the main project go to Manage Tab- Transfer Project Standards-select the other project as source of standars (on the top of the opened window ) and go to check only view template. Overwrite the existing or not ( as you wish). If you want delete the other View Templates that you are not using, go to Purge Paramenters in Manage tab. Check none and then go in view template: you have to select only templates that you want delete and preserve the others imported. I hope to helped you. Bye
Message 4 of 72
RobDraw
I do what @Anonymous suggests.
Rob
Message 5 of 72
As you wish. Two differet ways, same result
Message 6 of 72
RobDraw
One does exactly what the OP asked, the other requires bringing in more than is actually needed.
Rob
Message 7 of 72
'View Template' doesn't appear in the list.
No View Templates listed!!No View Templates listed!!
Message 8 of 72
The source file must have at least one View Template.
Message 9 of 72
RobDraw
Your source project is "Project 1".
Is that the project that you are trying to get the view template from?
The name implies that it might be the new project that you are transferring into, rather than from.
Rob
Message 10 of 72
Julian.Gherda
Hi all,
While looking for the same thing I've realized that the model from which we want to transfer  any view template needs to be linked in the "current" model. Also, at least in RVT 2018, I didn't get the option to select which view template to copy, and because we have a lot of view templates set up within the project template I got all instead on only one or two that I was looking for. Is there another way to only copy/import a view template from one model to another?
Message 11 of 72
RobDraw
Yes, that is necessary in order to transfer.
See message #2.
Rob
Message 12 of 72
Julian.Gherda
Thanks for replying Rob. It  is clear now that there no quick and easy way to do it. I was kind of hoping to be a way to do a simple copy/paste thinking there might be a file somewhere in the RVT folder.... I guess I have to dig dipper into how RVT works so I can understand what can be done, what can't and why.
Message 13 of 72
RobDraw
Forget about trying to figure out why. You're going to have just accept some things as "what Revit wants".
Rob
Message 14 of 72
Julian.Gherda
About that... my previous RVT senior told me that in some instances when normal things just don't work, he calls them Revitisms :))
Message 15 of 72
Hi all,
This is incorrect.  The source model does not need to be linked in the target model.  But it needs to be open in the same Revit session.
Message 16 of 72
RobDraw
Oops, I was mistaken in a previous post. Thanks for clearing that up for us @ToanDN .
Rob
Message 17 of 72
Doesn't work in 2020, only a few of the view templates from the original file come up for transfer:
Original file with view templates (opened in Rev****)
View templates available for transfer in the other file (also open in Rev****):
Isn't Rev**** just great? No, it's not, you actually have to get an add-in to perform a basically simple operation: https://apps.autodesk.com/RVT/en/Detail/Index?id=1809785843726173503&appLang=en&os=Win64&autostart=t...
Unfortunately to use this you have to link the file with the view template you want to transfer in to the target file. The app is available on the Autodesk site, why it's not an integrate part of Revit God only knows.
Rev****:
https://thinkmoult.com/why-revit-is-****.html
http://therevitmepskullfvck.blogspot.com/
Message 18 of 72
RobDraw
So, Revit tries to transfer all the view templates and if there are already templates with the same name Revit asks if you want to overwrite them or not. What is wrong with that? Is it supposed to read your mind? Because no one reading your post would know what you want to do either. Similar to life, Revit is only as great as the user driving it.
BTW, maybe you didn't notice that this thread is about transferring a single view template which is quite simple.
Rob
Message 19 of 72
martijn_pater
I think you would open up the file in same revit session which has the one template you want to transfer, delete all the templates you don't want to transfer, then transfer the remaining view template(s) and afterwards close the original file, without saving... Or 'just' reproduce the template settings in the other file for the one template...
Message 20 of 72
RobDraw
AFAIK, these are the only two ways to get a single (or multiple specific) view templates from one project to another.
Quite simple isn't it?
Rob
