Grid Ceiling
Grid Ceiling
abdurrashad187
Grid Ceiling
abdurrashad187
  1.  I created ceiling by using slop glazed roof and place custom panel family its placed 600x600m max distance is accurately at all but at one corner its deleted where space is less than 600mm how to adjust and fix this issue
SteveKStafford
Only the curtain wall/sloped glazing system curtain panels (Solid/Glazed/Empty) can contend with a panel shape that is not a simple rectangle. The corner condition can be a system panel family if you create a new type that has similar properties as your custom panel family.
Steve Stafford
abdurrashad187
you say right but if i apply system panal solid in this space that panal is without construction details so how i can add these details.solid panal.PNG
SteveKStafford
You can use the Empty Panel type and place a separate custom family to represent those panel locations. You should be able to use the mullions you're already using for the boundary edges. You can also duplicate and modify the properties of the solid panel to match your custom panel (material assignment and thickness).
Most of the time we don't model the actual ceiling components. We normally just use the ceiling family type and use a pattern to imply the grid layout. Using the sloped glazing will also require custom families to represent every element that will need to be hosted within the ceiling. I understand that doesn't produce a grid for model coordination in Navisworks for example so I understand the motivation to model the ceiling more accurately.
Steve Stafford
