Copy and Paste Dimensions
Paul.Lessa
Message 1 of 19
Paul.Lessa
How to copy and paste dimensions between views on the same project file?
I do tilt-up panel shop drawings and I usually show one panel per sheet 11x17 size. In a large job sometimes I have the same vertical string dimension for panel height, between reveal lines for more than 100 panels. Instead going thru this dimensioning process on every panel, I would like to copy the dimensions from the first one and paste them on the other panels. Please help.
Thank you,
Paul Lessa
Replies (18)
Message 2 of 19
loboarch
You can copy and paste dimensions from one view to another as long as the EXACT same objects are being dimensioned.
Dimensions in Revit are kind of like a report of a distance between 2 elements if the same elements are not there, then the dimension is essentially invalid.
So I am imagining what you are doing with tilt up panels are things that are the same size, but are not the same elements so it is failing.
If you have not already, you may want to look into using assemblies in your workflow and it may make some of this kind of work a bit easier by generating assembly views. This does not make dimensioning automatic but view creation might be easier.
http://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-EBB5B040-BEA8-4867-B245-8C1308EE3AE4
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 3 of 19
OlegSheydvasser
Another option is to use the Edit Pasted Elements command.
If the dimensions in the two views do not line up exactly, this command allows you to make adjustments before finalizing the paste operation.
The steps would be:
  • Copy the dimension in the 1st view (select it and hit control-C)
  • Go to the other view and paste (control-V)
  • Place the dimension in approximate position
  • Click on the Edit Pasted Elements button in the Ribbon
  • Select the dimension alone
  • Drag the dimension controls to new targets as needed
  • click Finish button
See details here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN....
Oleg Sheydvasser
Software Architect
Message 4 of 19
Paul.Lessa
Hi.
So you're saying if I have a building elevation showing 60 panels with 3/4" joint between them, and using assembly I'll be able to create views for individual panel to insert on a 11x17 sheet?
Thank you,
Paul Lessa
HP Consulting Systems, Inc.
www.hptiltwall.com
561-809-1358
Message 5 of 19
Paul.Lessa
Hi OlegSheydvasser.
Thank you for your help.
My problem is, after copying the dimensions to clipboard from view 1 I just can't past it on view 2. Nothing shows up when I hit ctrl-v or use paste from clipboard on Modify tab. Do you know why?
Thank you,
Paul Lessa
www.hptiltwall.com
561-809-1358
Message 6 of 19
loboarch
@Paul.Lessa wrote:
Hi.
Thank you,
Paul Lessa
www.hptiltwall.com
561-809-1358
Yes assemblies can help with this kind of workflow.
Jeff Hanson
Revit Help |
Message 7 of 19
OlegSheydvasser
@Paul.Lessa ,
Do you get an error message?
Can you copy - paste something else between the views, e.g. a detail line?
Oleg Sheydvasser
Software Architect
Message 8 of 19
Paul.Lessa
Hi Oleg.
A detail line I'm able to copy and paste, but if I choose one dimension and when I past it I got this error message. Please see attachment.
Probably I'll need to fix somethings before copying and pasting those dimensions.
Message 9 of 19
OlegSheydvasser
Hi @Paul.Lessa , sorry I don't see the attachment.
Is this the error message?
The selection can’t be pasted because it is not visible in this view.
Common causes and solutions
The category is not visible in this view (make category visible)
An annotation element falls outside this view’s annotation crop (temporarily disable annotation cropping)
The element tagged by an annotation is not visible (check view extents and depth)
I tried to paste a dimension from a plan into a section and got that message. Unchecking Crop View in the view properties allowed me to paste.
What kind of views are you copying between? Plans, sections, drafting views?
Oleg Sheydvasser
Software Architect
Message 10 of 19
Paul.Lessa
Yes, that's the error message I got.
This is what I did. I created one interior view from the west side of this warehouse. From that view I did duplicate view as dependent and then I used the hide crop region to show just one panel from that elevation. And then I started hiding in view the elements from other walls.
Message 11 of 19
OlegSheydvasser
So can you temporarily uncrop the view?
Oleg Sheydvasser
Software Architect
Message 12 of 19
OlegSheydvasser
Wait, if it's a dependent view, there's another option.
You can paste the dimension in the original view to the right location.
Then the dependent view will show the pasted dimension.
Oleg Sheydvasser
Software Architect
Message 13 of 19
Paul.Lessa
Hi Oleg.
I’ll do that and let you know.
Thank you,
Message 14 of 19
alejandro
I have a similar problem,  for example we add dimensions to a 2nd floor plan (complete floor plan with a huge number of dimensions) and when try to copy to 3rd floor ( which is almost the same or sometimes exactly the same ) it takes a lot of time, sometime crash or when we are lucky don’t copy most of dimension, just a few of them.
Message 15 of 19
bin
Apparently it will not work as expected. You may have walls, or grids showing on both level plans but you will not have the same doors, windows etc. even they look exactly the same.
Just imagine it as a tag.
Message 16 of 19
OlegSheydvasser
Hi @alejandro ,
Are you pasting Aligned to current view?
Pasting dimensions temporarily carries all the elements that dimensions point to, so it can take a while depending on your floor complexity.
Please do report crashes through CER dialog, we take the report seriously.
Oleg Sheydvasser
Software Architect
Message 17 of 19
Paul.Lessa
Hi Oleg.
I was able to copy dimensions from one wall panel to other wall panel. Instead duplicate as dependent I used duplicate with detailing. Duplicate as dependent option was showing all the dimensions from the panels on the main view (building elevation). And that was getting little bit messy.
Paul
Message 18 of 19
OlegSheydvasser
Paul, thank you for following up.
Would you mark the appropriate message as accepted solution so other forum users know which one to look at?
Oleg Sheydvasser
Software Architect
Message 19 of 19
m_delp
Hi Paul,
Go into your [Revit Options > Interface > shortcuts] and set yourself a shortcut for "Paste: aligned to current view".
I set the shortcut (ctrl+shift+v). Once that's done, try copying (ctrl+c) from one page and pasting-in-place (ctrl+shift+v) on the other page. Keep in mind the elements you are annotating must be EXACTLY at the same place. Always revise/verify the dimensions afterwards in case of bugs.
The inconvenience to this method:
You can no longer edit the dimensions references. If you want to remove a door from that string of dimensions, you'd have to remake it.
Let me know if this works for you!
Custom Build
Intel Core i7-8700K CPU @ 3.7GHz (12 CPUs)
64GB RAM - Corsair Vengeance LPX
NVIDIA GeForce GTX 1080
Revit 2019 | Sketchup 2020 | V-Ray Next
