Message 1 of 19
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How to copy and paste dimensions between views on the same project file?
I do tilt-up panel shop drawings and I usually show one panel per sheet 11x17 size. In a large job sometimes I have the same vertical string dimension for panel height, between reveal lines for more than 100 panels. Instead going thru this dimensioning process on every panel, I would like to copy the dimensions from the first one and paste them on the other panels. Please help.
Thank you,
Paul Lessa
