Model lines of Wall-Floor
4 ANTWORTEN 4
Nachricht 1 von 5
286 Aufrufe, 4 Antworten
Hi, guys.
join.pngIn some projects, in 3d veiw and elevations.
Lines between wall and floor does not disappear even though I
1. Joined wall and floor
2. Applied same material
3. Aligned wall and floor
4. Unjoined Geometry and rejoin.
5. Tried Switch join order,
Rather than just change line type with 'Linework', is there any other solutions to get rid of those lines?
Please help. Thank you
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
You could use the Linework Tool to remove the Lines.
Are you Phasing by chance? Change Phase Filter to Show Complete.
Nachricht 3 von 5
loboarch
You can move the edge of the floor so it is not going all the way out the the face of the wall. In reality it would stop a bit short and end some place "inside" the wall.
Without that I think the linework tool is the only choice, or turn off edges in the view.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 4 von 5
als Antwort auf: loboarch
...or make a band joist as separate wall around the perimeter of the floor, and join all the Walls.  Still Join Geometry should remove the visible edges between Floor and the Walls if they are all of the same material and aligned properly.
Nachricht 5 von 5
Try mitering the wall corners using Wall Joins Tool on Modify Tab.
