Coordination review cannot accept difference
 When something changes, coordination review highlights the change
but sometimes i can not accept the difference
for example, if a floor boundary changed, it tells me but the options are do nothing, postpone, ignore.
If a level name changed, the options are, do nothing and postpone.
What is the reason behind all this? Thank you
Is your project a workshared one?
If my answer solved your problem , Please Kudo  and Accept as solution.
Yes, it's a worksharedshared project.
Revit states a phrase about this specific question which says"The available action values vary depending on the type of change" so there is no other reason
for showing some actions and hiding others.
