Contour Label not showing correct value of Project base point
StephMarsh
Message 1 of 12
StephMarsh
My contour label is not showing the correct value.
I need it to be the project base point.
Replies (11)
Message 2 of 12
Well, then raise your Topo 467'-0".
I imagine that's not something you want to do.  Better to make you Contour Labels relative to the Survey Point and move the Survey Point ORIGIN, in Elevation View, to 467'-0" below that Spot and Contour Interval you are calling out in your screenshot.
Message 3 of 12
StephMarsh
Thank you for your response.
It is strange. I did set the survey point to 465'.
Then ran the contour tool and changed it to survey point. But it didn't read that elevation number.
Message 4 of 12
Just to be clear...
It's all relative.  Contour Labels and Spot Elevations are relative to a their Elevation Base.
Message 5 of 12
Is your survey point 465' below the contour yet?
Message 6 of 12
Did you move the Survey Point while CLIPPED so its Origin moved with it?
Message 7 of 12
StephMarsh
No I had to unclip it to move it.
Can you  move it clipped?
Message 8 of 12
What do you mean by "can you move it clipped?"  I guess that depends.  Do you have Links in the Project?
I mean, if you can't move the SP Origin, then make your Elevaton Base relative to a Level placed at -467'-0". Maybe name the Level "Sea Level".
Message 9 of 12
FWIW:  Clip vs. Pin
Message 10 of 12
StephMarsh
I will try that
Message 11 of 12
StephMarsh
Thanks. It worked making a level at 467'
Thank you so much
Message 12 of 12
Great! I look forward to receiving a Solution Credit from you then.
