Hello everyone,
I'm in the process of setting up our company's shared parameter file. Consolidating all shared parameters we use (from different sources) into a single file for ease of access and avoid a wild growth of said parameters. As well as avoid potential conflicts or errors in the future.
Reason being I made the mistake of creating an IFC shared parameter instead of adding it from the already existing "IFC Shared Parameters-RevitIFCBuiltIn.txt". Which took me some searching and time to clean up.
During the proces of consolidating I came across the "IFC Shared Parameters-RevitIFCBuiltIn-Type.txt". In this file I see the exact same names but appended with [Type] in the name and of course different GUIDS.
This made me wonder if I should have a similar setup for our company's shared parameter file(s) and how others handle this?
Please correct me if I am wrong, but the way I understand it (after reading different posts and forums) is that:
- there is no way to know/see if a specific parameter was intended as instance or type unless it was specified in the name or description
- upon creating/adding a shared parameter to a project or family you get to choose whether they will be instance or type based.
- the instance or type choice is not exported to the shared parameter file.
- if a parameter with that GUID was added to the project as instance but to a family as type at an earlier stage (by myself, by a colleague, by another company we work with or content creators) then the setting inside the project will override the setting in the family.
- above can also create conflicts (or lack of information) upon exchanging models (or IFC files) with others.
Since I am using pre-existing shared parameter files from IFC, the national standard NLRS, and our software supplier as a base for our company's (and only creating new shared parameters if I can't find any pre-existing ones) this is already a daunting job.
Before I double-up on this task I wanted to confirm
Hope someone can help and thanks in advance,
