Constraints not Satisfied error
I am trying to create a door panel with grooves in it. I have the panel itself as a family where I've created the void sweep groove and then array it and set up all parameters for if. When i flex the panel everything works fine. Then I load it into the Door Family and flex the door width and I get all of these errors. I've tried several different approaches and can't seem to find solution. Any help in this manner would be greatly appreciated.
Error message
Elements
Constraints are not satisfied Reference Planes : Reference Plane : id 78146
Generic Models : GS_Sticking_A : GS_Sticking_A : id 254636
Constraints : Linear Dimension Style : Alignment : id 255804
Constraints are not satisfied Reference Planes : Reference Plane : id 78147
Constraints : Linear Dimension Style : Alignment : id 255942
Constraints are not satisfied Reference Planes : Reference Plane : id 78152
Constraints : Linear Dimension Style : Alignment : id 255118
Constraints are not satisfied Reference Planes : Reference Plane : id 78497
Constraints : Linear Dimension Style : Alignment : id 254982
One or more dimension references are or have become invalid. Constraints : Linear Dimension Style : Alignment : id 254982
One or more dimension references are or have become invalid. Constraints : Linear Dimension Style : Alignment : id 255118
One or more dimension references are or have become invalid. Constraints : Linear Dimension Style : Alignment : id 255804
One or more dimension references are or have become invalid. Constraints : Linear Dimension Style : Alignment : id 255942
Can't make type "GS_Sticking_A". Generic Models : GS_Sticking_A : GS_Sticking_A : id 254636
Type : Generic Models : GS_Sticking_A : GS_Sticking_A : id 261869
An error occurred in family "GS_Sticking_A" that cannot be automatically resolved. Error Information: "Parameter Groove Spacing has an invalid value." GS_Sticking_A : id 255956
An error occurred in family "GS_Sticking_A" that cannot be automatically resolved. Error Information: "Parameter Void Count has an invalid value." GS_Sticking_A : id 255956
cbcarch
Sounds like you are over-constraining the nested door panel family into the host door family.
Try "loosing it up" by deleting a few dimensions and/or unlocking them from the panel to ref. planes in the door family.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Share the door family with the nested grooves.
