Connection visibility between element
lukas_hanakVFFNZ
lukas_hanakVFFNZ
Hi to everyone,
I would like to ask if there is a way to show contact lines. We are making a lot of axonometries in our company and we are modelling existing buildings as families, but the contact between the buliding and terraing isnt visible at all (see attached pictures - axo2 is how its supposed to look like)
I ran into the same problem when modelling two roofs connected together, the roof valley wasnt visible
Thanks in advacne for the answers
GHASEM_ARIYANI
hi @lukas_hanakVFFNZ
If you are using Revit 2024 or later and your topography is modeled with the Toposolid tool, you can make the contact lines visible by using the Join Geometry command between the building elements and the toposolid.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
lukas_hanakVFFNZ
It worked, thanks !
Such a beginner solution, dont know why this didnt come to my mind as well
