I would like to export a 3D Revit file to a 2D AutoCAD file with all 3D objects flattened and unclipped. I tried flattening a 3D .dwg file exported from Revit but my computer worked for hours unsuccessfully. I was able to get Revit to generate a 2D .dwg file but lower objects were clipped by higher objects---it just exported and flattened the view. I would like to see a 2D .dwg file with all objects laying on top of each other and preferably to remain in their block references. Note: this is a very large file of conveyors and platforms designed in 3D.
Place the 3D view on a sheet then export the sheet to DWG.
