connect roofs
4 REPLIES 4
255 Views, 4 Replies
connect roofs
Hi. Is there a way to connect these two roofs. One is roof by footprint, the other is roof by extrusion and they don't have intersection lines.
4 REPLIES 4
ennujozlagam
hello, you can try to use void extrusion/sweep then use cut geometry. i don't think you can join them. thanks
in reply to: ennujozlagam
Hi. it doesn't help much since there are no intersection lines can't do a precise void sweep or void extrusion. Yes, I just want to trim the roof not to join it
kittugs143
One roof with a sloped roof and another by face extrusion but if you noticed that the bottom of the roof is the same.
So if need to join this roof just give level offset for the roof (1/32") then add you can use join roof and hope it works.
Please find the image for more info :1.PNG
Best regards,
G.Sivakrishna
Product Specialist - AEC
You need to Align Eaves.
Plus, draw your Profile this way:
Forma Design Contest
