I am facing an issue, the quad corner mullion will (needs to be attached to two storefronts) but I need one side to be attached to a gypsum wall.. the soon I remove one side of the storefront the quad mullion goes with it. is there any solution?
Solved by RDAOU. Go to Solution.
Do not remove it... Select the panel (unpin if needed and replace it with a basic wall (Gypsum)
