Connect Quad Corner Mullion to Gypsum Board Wall
2 REPLIES 2
MKJOR
386 Views, 2 Replies
I am facing an issue, the quad corner mullion will (needs to be attached to two storefronts) but I need one side to be attached to a gypsum wall.. the soon I remove one side of the storefront the quad mullion goes with it. is there any solution?
2 REPLIES 2
RDAOU
in reply to: MKJOR
@MKJOR
Do not remove it... Select the panel (unpin if needed and replace it with a basic wall (Gypsum)
GHASEM_ARIYANI
in reply to: MKJOR
Hello @MKJOR
please See attached video:
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
