Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
Did you mean:Ā
Concrete crack modelling
9 REPLIES 9
Message 1 of 10
1894 Views, 9 Replies
Is there any way i can put concrete crack information in BIM model ? Suppose I have measured the concrete crack, width, length and orientation on site and i want this to be depicted on my model so that it can show on-site condition. Can this be done ?
9 REPLIES 9
Message 2 of 10
Create in place generic families, draw model lines on surfaces of the concrete, use Comments or add other parameters to describe the damages. Then you can schedule them if need be,
Message 3 of 10
constantin.stroescu
I suggest , as ToanDN already said, to use Model Lines and if you want to make a list with all these cracks and there total length , to use Dynamo..as shown in my screencast
Constantin Stroescu
Message 4 of 10
in reply to: constantin.stroescu
Dear Sir,
Thanks a lot. This is very helpful. I just have one last question. Can i automate this via API ? I have crack dimensions coming from a python code that i am planning to make which automatically calculates them. I also have a building model in Revit. I want the python program to automatically draw these cracks via API! Do you think it's possible or i can't fully automate the process ?
Message 5 of 10
do you mean like in this picture is it possible to do that in revit?concret.JPG
Message 6 of 10
Yes, like the picture would be fine. But need it on the BIM model.
Message 7 of 10
Even i have the same doubt. if you find any way of modelling it please help me as well
Message 8 of 10
Mohamed-Nassar
you can create in place void ? could you try this and tell me your opinion
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 9 of 10
syman2000
I use model text and it works well.
Message 10 of 10
UsualUser
in reply to: syman2000
Could you please explain how you could change a letter to a drawing in the model text?
Forma Design Contest
