Conceptual mass modelling problem.
e234606
e234606
Hey guys, am going to need somehelp. Am trying to model a conceptual mass but am running into some problems, just got revit 2024.
1. The reference lines arent dotted lines as am used to.
2. The reference lines in the floor, arent showing up in the elevations. This is my biggest issue as I cant continue modelling without seeing the reference line in the elevations.
Any help will be greatly appreciated
juliar123
My 2024 and 2023 mass modeling environments look pretty much the same. You can't usually see reference planes that aren't perpendicular in your elevation, unless you set your reference plan and select Show. Is this what you mean be seeing reference planes?
