Resize and make rid of quote dimensions in making families
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
mzmaso90
318 Aufrufe, 4 Antworten
mzmaso90_0-1685628229195.pngI found the way how revit is planned quite disturbing, for example when I uses dimensions to create parameters, It's being impossible due to the big size of other quote , I cant really rid of them, even resize down to 0,2. Any considerations to work easily with quote and east-west-sud-north views? for families?
4 ANTWORTEN 4
Nachricht 2 von 5
mhiserZFHXS
als Antwort auf: mzmaso90
Change the scale of the view.
Nachricht 3 von 5
mzmaso90
Yes, I rembered later, so frustrating. Do you now how to easily set up a slop parameters that will works with a mass family? I tried to applied to reference planes, but I might uses reference lines?
Nachricht 4 von 5
mhiserZFHXS
That's not really related to the initial thread, but it'd be helpful to know more. Is it a ramp or something? How do you want to control it? You could technically do it without a formal slope parameter and just have a length and height parameter.
Nachricht 5 von 5
mzmaso90
als Antwort auf: mhiserZFHXS
Hi ! I tried to create a family  Solar Panel looking forward to pick-up informations briefly  from Forum-queries, but, as you know, roofs and other categories which can be modelled in Revit and could be selected for Solar Analysis, do not furnish well results in terms of radiations, because when you change the slope, you modify the total area, with a considerable aumentation of it. So i used a mass, that is the only right solution to perceive the solar quantity of radiations but it request a good understandings of commands to finalize  parametres such slope, in a quick way to accomplish the model. Could you help me about this factors?
Best Regards
Thank you
Lorenzo
Best Regards
