Combine categories in one schedule?
nic5YH8X
nic5YH8X
How can I combine the site area and a gross building area in the same schedule?
syman2000
You can add site area to project information. Afterward you pull the project information from your gross area schedule
nic5YH8X
Would this involve me manually entering the site area into the project information?
It would be great if it could automatically be generated from the property lines
Yes you can.
Create a 'site' level and draw the area separation lines by picking/constraining to the property lines + area on that level, under the same area schemes.
syman2000
Unfortunately yes. You have to enter the info manually.
handjonathan
Hi @nic5YH8X
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @syman2000 @ToanDN  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
