- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
They're visible just fine in floor plans where cut plane actually goes through them. But I'm using the "invisible model line" trick to also make columns visible in foundation plans, where they're not cut.
In that plan they're invisible, I've traced the issue down to beams that automatically join to them when beams are placed. They don't even have the same material, I guess Revit just automatically joins structural elements.
When unjoined they become visible.
Any way to get them to show, aside from manually unjoining every column?
Using Revits out of the box concrete beams and concrete columns families.
Attached video of the issue and rvt file with offending elements.
