Hi all,
See the wall type only has 4 layers,
but in floor plans & both wall details there's an extra <HIGHLIGHTED IN YELLOW> layer.
What is the potential issue?
IS there any quick way to fix it up except for MASKING REGIONS?
TQ
jiner
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
you have sweeps or reveals?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
That is a sweep embed to the wall type. Edit the wall type and open sweep dialog to delete it.
