Hello all!
It is possible to do a schedule similar to the following one?
With subtotals and totals in columns?
Thank you!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Yes. By adding a calculated value parameter for each subtotal column. Share a sample model then I can show you.
Hi! @ToanDN
I have linked a file with an example, you will see that there is an schedule that already have the parameter JML_Location.
In Excel, the formula would be something like:
Column PR 01
=if(PR_Location="PR 01", count,"-")
Column PR 02
=if(PR_Location="PR 02", count,"-")
Column PR 03
=if(PR_Location="PR 03", count,"-")
Column Total
Count
Thank you!
You can use nested IF statements in a Calculated Parameter. See "IF AND OR Returning the greatest of three values".
https://www.revitforum.org/node/1126
Also note that Conditional statements can only evaluate numeric values, numeric parameter names, and Yes/No parameters. Not Text.
About Calculated Parameters:
See Revit 2019 file (I do not have 2018), it should explain itself. If you cannot open it then I can explain with some screenshots.
THANK YOU!!!!!
I got it!
First intent I couldn't because i didn't activate the calculation in the format, second, it went GREAT!!!
If I would know I would create my shared parameter as integer.
I don't get to understand this integers very well.
Best regards!!!!!
