This is a view of part of a wall. How id the "Cloud" effect achieved? Is it in the material or is a display setting?
Solved by tmccar. Go to Solution.
Use a Background Image.
...maybe I misunderstood. Is that the look of the Material on the surface of a building element in background? If so, what View/Detail Level/Visual Style do you need it to show in? You could create the effect internally by overlaying Views on a Sheet.
Huh? Well, if it's there and it's in fact a background image, then follow the path shown under GDO to see where it leads you.
