How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Hi everyone! I'm doing shcedules quantities of a wall, but i'm using wall reveals for discount wall areas and it doesn't works, do you know if its possible to discount it using wall reveals?
Did you use paint that wall surface? If I do that, it will separate the area from paint and non-painted
If I remove the paint, it won't calculate the area
Instead of Wall: Reveals, you can use an in-place Generic Model void to cut the layer you want to deduct.
Otherwise, to discount material using reveals you need to do either of the following
Option 1: Convert the wall to Parts and use a Parts Material Take Off schedule
Option 2: Material need to be applied as PAINT and use a Walls Material Take Off schedule (Filter material which are applied as paint)
How to buy
Type a product name
