Wall reveal
2 REPLIES 2
santiagoquinterolopez
424 Views, 2 Replies
Wall reveal
Hi everyone! I'm doing shcedules quantities of a wall, but i'm using wall reveals for discount wall areas and it doesn't works, do you know if its possible to discount it using wall reveals?
Wall reveal
Labels (3)
2 REPLIES 2
syman2000
Did you use paint that wall surface? If I do that, it will separate the area from paint and non-painted
If I remove the paint, it won't calculate the area
RDAOU
@santiagoquinterolopez
Instead of Wall: Reveals, you can use an in-place Generic Model void to cut the layer you want to deduct.
Otherwise, to discount material using reveals you need to do either of the following
Option 1:  Convert the wall to Parts and use a Parts Material Take Off schedule
Option 2: Material need to be applied as PAINT and use a Walls Material Take Off schedule (Filter material which are applied as paint)
