@Edusoftsts
If you want an easy one .. use 2 Curtain walls
- First wall: With Border Mullions and Horizontal Interm ones
- Second wall: With only Vertical Interm Mullions
Another option is to integrate mullions in the panel but then the downsides are
- if you are editing profile of the wall or attaching its top to a non-horizontal roof, the panels will not follow form
- You will need more custom panels for the border tiles that has mullions nested to 3 sides only and 2 sides at the corners
- Quantification of mullions becomes quite tedious
Alternatively, you can model the CW using a divided surface and Pattern Based Curtain Panels...You should find lots of tutorials for this method on youtube
