hi friends
I can't make a perfect mullion joint in the curtain wall using a circular profile. Here i attach the reference pic. Pls, help me to solve this.
Edusoft
Solved by RDAOU. Go to Solution.
If you want an easy one .. use 2 Curtain walls
Another option is to integrate mullions in the panel but then the downsides are
Alternatively, you can model the CW using a divided surface and Pattern Based Curtain Panels...You should find lots of tutorials for this method on youtube
There are several ways:
Here is a YT on how to make them using pattern based (instead of a rectangular profile use a circular) but again if the border frame/mullions are not circular you will need to work on the corner and border panels + to quantify you will need to work with nested shared components and shared parameters for the mullion extrusion.
Same principle applies to the Custom Curtain Wall Panel with integrated mullion. Instead of using the Curtain Panel Pattern Based.rft template used in the below video, you would use the standard Curtain Wall Panel.rft
https://www.youtube.com/watch?v=WoqzTKB0Kcw
