I have a problem with exporting Revit model using ETransmit
With file addition settings disabled (in Etransmit), all IFC files are unloaded (and from the links)
Is there a solution?
Version: Revit 2021 and Revit 2022
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
FWIW: I'm not experiencing any like issues. IFC Link transmits successfully with Project.
It should compile IFC links even if you un-check all the boxes/options.
You need to look into the folder where those IFC files are located. IFC will not be included in the ETransmit in the following cases
The whole idea is to transmit the entire model without having to compile it all manually.
If you prefer the manual way, simply use the conventional Detached central copy.
