Changing Spiral staircase run
ahmedroushdy01
ahmedroushdy01
I have a task so we have modeld a customize step in 3d model in place, hence we need to make spiral staircase with these modeled 3d step. How to make this please
Provide us with the drawing/specs and we'll show you how to get there.
ahmedroushdy01
So i want to make my stairs like this
ahmedroushdy01
To make this spiral stair
jay_colc
The stair tool uses a profile to create the treads so this would be beyond the scope of what a standard profile would achieve.
You would need to model this a single model element, you could then create the spiral stair element as a placement guide then rotate each element to suit and change the elevation to match the steps heights etc.
Alternatively with the modelled tread component, create the stair using more advanced Revit adaptive family features
Jay Colcombe
Autodesk Certified Instructor
GHASEM_ARIYANI
hi
you can use the Rail Tool. Watch the video below.
I hope I have helped
https://youtu.be/rx5Fjl3myYQ
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Model that single tread as a Baluster and use in a Railing Type as the "Use Baluster per Tread on Stairs" Baluster Family Type - and then host the Railing to a Spiral Stair. The Spiral Stair is just a Reference Host and need not be visible in Views.
I spoke about using Balusters for Treads on this Post - with illustrations:
Re: custome tread and riser in revit stairs - Autodesk Community - Revit Products
