Change witness lines to two different types
sbarron
Message 1 of 8
sbarron
I see how to change the witness lines in dimension styles.  My question is is it possible to have a different line style for each witness line?  I would like a solid line dimension from a wall, but a centerline style for the other witness line when it is to a column centerline, plumbing fixture centerline, etc.  I know this is possible in AutoCad, but cannot figure it out in Revit.
Replies (7)
Message 2 of 8
Yien_Chao
nope. you will need 2 types.
Message 3 of 8
You mean this?
Message 4 of 8
sbarron
no, like this.
Message 5 of 8
Yes, you can do that. Look at the Type Properties of the Dimension Type in the above Screenshot I posted.
Message 6 of 8
Yien_Chao
I though you wanted 2 styles depending on what you are dimensioning.
Message 7 of 8
sbarron
No, one style with two different witness lines, depending on what I am dimensioning.
Message 8 of 8
Sure thing.  Edit your dimension type and assign a centerline pattern to center reference.  For it to work, the witness must be a center reference plane in a family.
