How to create a sloped floor and a floor with a varied thickness in Revit
ahmadkhalaf7892
ahmadkhalaf7892
 Hello Guys how can I create a floor like this and add a slope to it ? Or there any way I can create a floor family that would have this shape and add a slopearrow to it ?
When I am using the add point method and slopearrow method I am getting an error.
SO I want to create a standared floor Family that looks like the above photo and I want it to have a slope in the Z direction .
I am getting a lot of errors when I am placing it as a variable Floor and try to add a slope to it .
Simon_Weel
A variable thickness AND a slope can't be done in a single floor. I guess you could create wo floors - one sloped and one with a variable thickness and then join them:
d.ahmed.LW
Hi @ahmadkhalaf7892
where exactly are you facing the issue? I used the points to give it a higher value and set the material as Variable. Am I missing something in your question?
ahmadkhalaf7892
 Hi Ahmed , WHen I add Points to the floor it works fine the shape is changed , however I am trying to add a slope to it using a slope arrow and I am getting an error. Apparently I cannot do that in Revit .
I want the shape indicated in the first question to be following a certain profile(elevations) using slope arrows or any other method .Like this I mean , however it would have the shape indicated in the first question
is there any way I can create a standard Floor family maybe that would have the above shape ? Or any idea to achieve this .
hmunsell
You can make a Variable layer in a floor type that can be adjusted by points, but it cant be sloped ☹️.
You could try making a Model-In-Place floor and pick the Floor category. Then draw your Profile of the floor with the slopes you want.
Howard Munsell
I'm scratching my head here too.  Why would you need a Slope Arrow?  The Floor is sloped already.  Are you trying to create two slopes?
ahmadkhalaf7892
I am trying to have this constant variable floor   shape like the photo above.
However at the same time I am trying to add a slope in the z elevation without changing the shape in it(Add z Elevations for the floor shape in the photo) .
The reason for this is that I am working with Revit Api for a tunnel cross section and I ma trying to see if it can be done manually then automatically.
