Change the row height and column width in Revit Schedules
wjxu55
wjxu55
Revit schedule row height and column width controlled  Body text size.  It is possible  to change the row height and column width in Revit instead of change Body text size?
Thanks!
Willie
Shift+enter and type in a period or paste in an Unicode character if you want no dots.
Corsten.Au
Hi..
Horizontal resize is available any time...but verticle one gets activated if you have an image parameter in the schedule..
check this out .
Resize ColumnResize ColumnResize RowResize Row
Corsten
Building Designer
wjxu55
I'll try to practice both them above!
Thanks all.
Willie
jayhar
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
