Change mm to meter
Change mm to meter
lubgubannadine1
Observer Observer
Change mm to meter
lubgubannadine1
Observer
Observer
Hello. I wanted to ask for help with the dimensions. I wanted to ask for help how to change mm to meters completely, I already change the project units to meters but whenever I placed dimensions on the walls etc. .. The numbers are always in millimeters which is my problem because I want it in meters like for example 1.20 Meters not 1200 . I have solved this before but I forgot how since it's been years I haven't opened Revit... Hoping for someone to help. Thank you
Change the Units used by the Dimension Type under it's Type Properties.
ralphdenhaan
Make sure your dimension type is set to: Use project settings: change-units-revit/
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
SteveKStafford
Project Units > Length defines the "global" project units for all dimensions that are set to use Project Settings. If you set all of your dimension styles to that then changing it once will update them all. If any are overriding Project Units then you have to adjust them in each dimension style separately.
Steve Stafford
