Change Date Format
Change Date Format
Seychellian
Change Date Format
Seychellian
Anyone know how I can change the date format in Revit (specifically in a label)?
At the moment the Revit default date format is formatted numerically and doesn't match our office standard (as seen below).
constantin.stroescu
you have to do it from Windows 10 settings:
https://www.google.com/search?q=windows+10+change+date+format&rlz=1C1GCEA_enRO851RO851&oq=windows+10...
and Loaded into the Title Bloc as Label and then into the Sheet in Project:
Constantin Stroescu
constantin.stroescu
but , if you don't want the Data Stamp that is automatically, then use Project Issue Date that is manually from Manage >Project Information> Other >Project Issue Date. You type the text  as you want....
Constantin Stroescu
