Hi there,
I want to show both phases (Please see attached pic., yellow is demolition and light red is new) in the same floor plan, but when the components overlap, I want the new phase to overlap the demolition one.
Is there a way to control this issue?
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
I do not see this behaviour (Revit 2020.2)
I see the the new over the demolished
I only can replicate what you have is when the new wall is seen a projection/surface (below cut plane) and the demolished wall cut (above cutplane).
Maybe you can upload (relevant part of) your project? Which Revit version did you use?
Louis
Please mention Revit version, especially when uploading Revit files.
Hello everyone.
I'd like to come back to this topic, since we are experiencing a similar problem in the Revit 2023.1.1.
Is there a known solution for this problem. Here I send a screenshot where we see that the new walls are behind the demolished ones (optimally, the graphics should be the other way around), but some other elements, like new columns, will be displayed over the demolished ones.
Thank you very much in advance for your help in this issue!
