Change colour of nested generic annoations in linked model
rickyleaburke
rickyleaburke
I have a model into which a number of houses (sub models) are linked.
Each sub model contains electrical components, such as sockets, the families for which comprise modeled elements and generic annotations.
I am unable to change the colour of generic annotations (in this case electronic symbols) nested within a component (electrical component) in the 'Master' Revit model.
This is important, as we colour code our M and E on drawing outputs and this limitation means we cannot do so.
Can anyone please help?
Some options I have already exhausted:
- Object styles: these have no effect on a nested symbol
- Override by elements to an alternative colour: this is not allowed for linked models
Alfredo_Medina
If possible, contact the author of that model, explain the problem, and ask them to modify those families.
Did you try to override the Visibility/Graphic of the Revit link?
rickyleaburke
Thank you,
Must remember to check linked overrides as well as the main VG for the model.
Alfredo_Medina
If the color in that family does not mean anything in the current project, and if you are going to collaborate with that other firm for a while, you should still contact them and ask them to modify that family. That's what BIM standards are for. You shouldn't have to do this visibility setting things to correct a color that somebody is using without any meaning in the project.
