Change appearance of Generic Model
cbt990
Message 1 of 10
cbt990
There are about 20 instances of a perforated metal balcony privacy screen that was originally made from a 3dm import.
As far as I can tell, revit is giving me no ways to change the appearance of the model.
Am I out of luck? I couldn't find it in object styles or in the browser, either.
Revit is amazing
Replies (9)
Message 2 of 10
Sure you can.
Message 3 of 10
cbt990
I looked here, no luck:
Revit is amazing
Message 4 of 10
Expand this.
Message 5 of 10
cbt990
I tried changing the one item set to render in Grey and it doesn't seem to have done the trick.
Revit is amazing
Message 6 of 10
No issues here.  What is your view visual styles?  Are you sure you change the material for the correct layer?
Message 7 of 10
cbt990
Sorry, i meant to suggest that the item we are searching for is not in that list.
Revit is amazing
Message 8 of 10
cbt990
Pasted it into a new project.
It only responds to a change if I change the entire generic models category.
Revit is amazing
Message 9 of 10
cbt990
Solved by creating a part from the generic model.
Revit is amazing
Message 10 of 10
Because you imported the 3DM in as a Direct Shape so there are no layers.  Import it in normally:
- Create a blank family or in place family
- Link CAD > choose the 3DM
