Announcements
Annotated hidden lines from family display solid in model.
bharrisQ72UN
bharrisQ72UN
I have this issue with all family components I bring in that I have annotated lines that have a hidden pattern.  They always show solid even though when I hover over the component it will show which lines are supposed to be hidden.
I've checked the object styles and every hidden line subcategory is correct.  And Show Hidden Lines are set to "By Discipline".  I've checked all the V/G Overrides and they're not the problem.  The images below are just an example. It happens with every component though.
Replies (14)
Is the view Wireframe or Hidden?
Lower View Range Bottom or set it to Unlimited and see what gives you.
bharrisQ72UN
It's set to hidden. Both lowered the view range level and then set it to unlimited and no change.
Share the file here.
Component Stairs? Check your <Above> Subcategories under Stair Category in VGOs/Object Styles.
BTW: If we are talking about Stairs, Revit doesn't display Stair Model Components in Plan/RCP Views. What you are seeing is Symbolic.
...compare Plan View of Stairs with a 3D Plan View of Stairs to see what I mean.
bharrisQ72UN
Stairs may not have been the best example.  In interior elevations door swing lines display solid instead of dashed as well.  Any symbolic line annotations display solid in the model.
Sounds like a View Scale thing to me.
Can you your show the View Range settings?
bharrisQ72UN
I've also tried Top: Associated Level/View Depth: Unlimited, Top: Unlimited/View Depth: Associated Level, and Top: Associated Level/View Depth: Associated Level.  Nothing helped.
Not View Scale related?
Post the file and start your stopwatch.  Betcha we figure it out in 10 seconds.
Try View Bottom = Unlimited.
bharrisQ72UN
The file I'm working on is way too large to upload so I did a test file that has all the same problems.  If you can figure it out in 10 seconds that would be awesome!
Check you Phase filters and Phase graphic overrides.
bharrisQ72UN
Hot dog that did it! Thank you all so much!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
