Change appearance of Generic Model
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
cbt990
673 Aufrufe, 9 Antworten
There are about 20 instances of a perforated metal balcony privacy screen that was originally made from a 3dm import.
As far as I can tell, revit is giving me no ways to change the appearance of the model.
Am I out of luck? I couldn't find it in object styles or in the browser, either.
Revit is amazing
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: cbt990
Sure you can.
Nachricht 3 von 10
cbt990
als Antwort auf: ToanDN
I looked here, no luck:
Revit is amazing
Nachricht 4 von 10
Expand this.
Nachricht 5 von 10
cbt990
I tried changing the one item set to render in Grey and it doesn't seem to have done the trick.
Revit is amazing
Nachricht 6 von 10
No issues here.  What is your view visual styles?  Are you sure you change the material for the correct layer?
Nachricht 7 von 10
cbt990
Sorry, i meant to suggest that the item we are searching for is not in that list.
Revit is amazing
Nachricht 8 von 10
cbt990
Pasted it into a new project.
It only responds to a change if I change the entire generic models category.
Revit is amazing
Nachricht 9 von 10
cbt990
Solved by creating a part from the generic model.
Revit is amazing
Nachricht 10 von 10
Because you imported the 3DM in as a Direct Shape so there are no layers.  Import it in normally:
- Create a blank family or in place family
- Link CAD > choose the 3DM
