Central model cannot be found
Message 1 of 18
@ToanDN
Good morning Mr. @ToanDN, I have an issue, maybe you could please help me resolving this:
Please see the attached images so you can have a better idea of what is going on (I was unable to attach 6 images, so I had to split this post in 2 parts, containing 3 images each);
I made a copy of a Revit model so that I can make changes and preserve the original client file. As soon as I open that, I get those error messages shown in the images.
When I open a floor plan in the original file it shows everything and when I open THE SAME view in my copy it looks completely different. any suggestions please?
Thank you
File issues 1 of 2
Replies (17)
Message 2 of 18
@ToanDN
Thank you
File issues 2 of 2
Message 3 of 18
Just open the original file, tick Detach from Central box, then Save As a new file to work on.
Message 4 of 18
Thank you for your message. I tried this before and it does not work.
Thank you
Pedro
Message 5 of 18
Thank you
Pedro
You said if you open the original file, everything is fine.  What happens when you open it with the Detach box checked?
Also, does the original file come with any linked files?  If it does then the copy may lost the links due to pathing.
Message 6 of 18
SteveKStafford
That message goes to the fundamental nature of Central and Local Files. A copy of a Central File IS a Local File fundamentally. If a Central File is moved to another folder or that folder is renamed Revit regards that situation as if the file is a Local File now.
As such a Central File must be saved deliberately creating a new Central File in order to move it, saved to its new location and specifically telling Revit to make it a Central File again. The Detach from Central process is a shortcut for that because it presumes the file must be Saved first in order to resume its status as a Central File again.
As @ToanDN suggested, to create a copy of the project that is not connected to the original project anymore, use Detach from Central and when you Save the file for the first time after doing that you'll be asked to provide a name and location. If you wish to preserve the original project file, save it using a new name and location. If you're trying to replace the original overwrite the original (though I never do that before archiving the original). Make sure nobody else is working on the project before doing this.
Steve Stafford
Message 7 of 18
No, the Original file is clean, no linked files.
I do everything, I always follow all the protocols. I open the original file, detach from central, save as another name in another folder, make the "new" file like a central one and, when I open the level that I need to work on, it looks completely different: no stairs, no walls...
Thank you
Message 8 of 18
Any chances you can share the save-as version of the file?
Message 9 of 18
I was trying to attach one compressed and it doesn't allow me to. I will upload to my gmail drive and share with you, may I have please your email address?
Thank you
Pedro Ospina
Bachelor in Architecture - Naval Architecture Student
Message 10 of 18
I opened it detached, save as to a new central file, close, open the new file and the model is there, the view shows normally.
Message 11 of 18
Viveka_CD
Hi @Anonymous
Did the recommendations by the experts help with your issue? Please accept the response as the solution if it did.
Else, you are welcome to create a support case with us and provide a data-set for further investigation. Let me know and I'll be glad to help your further.
Message 12 of 18
Good morning, I never posted any question to this forum called "Central model cannot be found"
Message 13 of 18
Thank you.
It's weird. Could you please open both the Original and the Copy, open the same view as the attached images, compare them and see how they look?
Thank you
Message 14 of 18
I never posted this question under "Central model cannot be found" I had to split my question "File Issues" in 2 postings so that I was able to attach 6 explanatory images: This Revit forum allows users to attach only 3 images...
Just to clarify.
Message 15 of 18
Who changed the name of my posting? it's creating confusion.
Message 16 of 18
@Anonymous wrote:
Thank you.
Thank you
They show exactly the same.  Below is form the Original, what I posted earlier is from the copy.
By the way, don't attach images, use Photo button to embed them in your post.
Message 17 of 18
yes it's a good idea attaching photos to the post, thank you. I didn't pay attention on this
I don't even know what is going on with my files. the thing is, when I open another file with the copy one linked, it shows perfect.
I would like to accept your answers like solution but at this time it won't be possible, thank you again for your kindly effort.
I will try to figure what is going on. I need to make some work on the copied one.
Thank you
Message 18 of 18
Thank you I have already figure this out.
