Ceiling Grids at multiple elevations
advandes
Advisor Advisor
advandes
Please see attached PDF. How can I get the higher ceiling grid (14'-0") to show up in this view? I have tried to use a plan region, but I think ceiling grids use a different concept with view depths that I just don't understand. Thanks!
AAG
Advance Design
Change Top offset to 14' or more.
robert.klempau
Hello @advandes,
set your View range as followed:
Or draw a Plan Region with the following View Range Settings:
That should do it.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
advandes
I have tried that. I get the following error:
Error: View depth plane is set below the top clip plane.
I think ceiling grid view planes are upside down??
AAG
Advance Design
advandes
Thanks. Either way worked... Awesome!
AAG
Advance Design
...that's because it's backass-backwards with RCP view range...
rmc9WR3X
Is the behavior for RCP offsets the same as for Plans, meaning a positive value like 16' is offsetting upward (going toward the sky) from the target plane, and a negative value like -9' is offsetting downward (going toward the earth)?
