cannot select 3d object in Revit
XiaolinHan
Message 1 of 8
XiaolinHan
Hi every one,
sometimes I cannot select the building parts such as concrete wall, floorslab, columns, furniture and so on. But I can select all rooms, axises, measurements and tags.
It's not about  the Select option on the upper left or the under right corner,  it is also not about design option, nothing is pinned. It is also not a linked model.
I have tried reopen Revit and restart PC, doesn't work.
But this problem only exists in floorplan, not in 3D View. I am driving crazy about it, since you don't know, when it could happen, and when it will be again fixed automatically.
Does someone have the same problem?
Thank you all,
bests,
Replies (7)
Message 2 of 8
TAB-Select not working?
Message 3 of 8
Design Option? Did you make it editable?
...Dedicated Views make DOs a lot easier to work with.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M....
Message 4 of 8
XiaolinHan
Hi, barthbradley
thank you for the reply, tab select didn't work.
Message 5 of 8
XiaolinHan
it ist also not about design option. we did not have any design option. I just noticed that, sometimes it will be solved, when other colleagues the model synchronize,  but it does not work always.
Message 6 of 8
Do you have any large filled region in the view?
Message 7 of 8
XiaolinHan
Hi, yes, there is a cad link of topography!
Message 8 of 8
XiaolinHan
But it is not filled region 😂
