Adjust feef of a handrail to an step width.
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
Darwin33
822 Aufrufe, 16 Antworten
I have to adjust the feet of a handrail to a witdth of a step. My problem is that my step can not divided in whole numbers so I can not place a digit in the properties window. Is there a way to adjust the feet of a handrail to a non whole number distance?
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: Darwin33
What about Edit Rail and sketching it?
Nachricht 3 von 17
Do you mean the bottom extension of the handrail?
Nachricht 4 von 17
Nachricht 5 von 17
Darwin33
als Antwort auf: barthbradley
How can I get that menu.
Nachricht 6 von 17
Mike.FORM
select your railing, click edit type in properties and then click the circled [...] button as shown.
Nachricht 7 von 17
Darwin33
Thank for all your help, now I am almost done but I have 2 more questions. My handrail need a plate embedded in the floor, like in the attached sketch. How can I make it?
Also at the end the staircase has a horizontal flight, how can I create this horizontal flight. See also attached sketch.
Nachricht 8 von 17
Mike.FORM
That is a little bit trickier to accomplish but you can do it by editing your baluster family and adding a foot that extends to the left and add a dimension parameter to its length so it can be adjusted. The have it extend the length of the gap between balusters. It won't be a continuous plate at the bottom but every baluster will have a foot on it so it will appear continuous.
Nachricht 9 von 17
- Model the railing using Curtain Wall and Edit Profile
- Model the plate as baluster of a separate railing
Add a top landing by sketch.
Nachricht 10 von 17
Make the bottom rail a stair type and host your railing to it.
Nachricht 11 von 17
Darwin33
I have one more question, is it possible to create a horizontal handrail and then edit the end feet height so I can have an slanted top railing like in the attached sketch.
Nachricht 12 von 17
Darwin33
Also is it possible to remove the first rise of the stair?
Check the attached sketch.
Nachricht 13 von 17
Darwin33
Is it possible to remove the first riser.
Please see the attached sketch.
Regards
Nachricht 14 von 17
Edit Stair and Untick Begin with Riser.
Nachricht 15 von 17
Darwin33
I dont find that option in my menu. Sorry it is in German.
Am I in the right chart?
Nachricht 16 von 17
Edit the stair, select a run and you can see the option.
Nachricht 17 von 17
You need to select the Stairs that are the Bottom Rail and press Edit Stairs - and then select the Stair again to reveal "Begin with Riser" checkbox under the Properties.
