cannot open/link ifc file into revit
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I am trying to link an ifc file into revit. The ifc file comes from the building-smart website example (url: http://www.buildingsmart-tech.org/implementation/get-started/hello-world/example-1)which is generated by code:
and I can open and view the ifc file by ifcViewer and navisworks:
However I cannot open/link this file into revit(both 2016 and 2018, and ifc latest plug-in added), when I tried to open/link the ifc file, nothing happens. I googled and found this thread: https://forums.autodesk.com/t5/revit-architecture-forum/rvt2018-can-t-open-link-ifc-files-failed-to-...
I followed the instrution to download a rte file but still failed in opening the ifc file. By the way the file size is very small so should not be the size problem.
I have appended the ifc file in the attachment (the website does not support .ifc file as valid extension so I added the .txt extention, if you download the file, just use the .ifc extension) and hope if any one could help me with it.
