RVT2018: Can't open/link IFC files.(Failed to open)
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
6205 Aufrufe, 14 Antworten
I recently installed Revit 2018.
Now I can't Link IFC or even open them to make .RVTs of them.
It says Failed to Open document.
In the IFC.log file it says this.
"Warnings and Errors
General ERROR: Can't open template file(s) C:\ProgramData\Autodesk\RVT 2018\Templates\Sweden\Structural Analysis-DefaultSWEENU.rte to create link document, aborting import."
The templates file are there.
After installation i only have the Structure template as standard. MEP and Arch. is gone.
14 ANTWORTEN 14
Nachricht 2 von 15
markcalloway
als Antwort auf: Anonymous
Hi @Anonymous
What application did the IFC come from and what type of IFC is it?
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Nachricht 3 von 15
als Antwort auf: markcalloway
@markcalloway
Hi Mark,
The IFCs are from AutoCAD. I got about 11 different IFCs from different people in this project. I can't open any of them, after installing RVT2018.
Most of the IFCs contain data from other apps like MagiCAD (Pipes and Ventilation, Electric). But I can't link/open earlier versions of the same files either.
I'm also missing template files. Which is strange, since I'm almost 100% sure I installed a full copy for Revit (Arch, MEP, Struction).
Nachricht 4 von 15
markcalloway
Hi @Anonymous
If your templates are missing in Revit they can easily be added back, I recorded a short screencast not so long back showing how to do this:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/screencast/Main/Details/59230b0d-4b78-4602-9dab-605d4dfdbede.html
Nachricht 5 von 15
markcalloway
Are you allowed to upload any of these IFCs for us to look at?
I'm assuming you are importing them as per these instructions:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Nachricht 6 von 15
@markcalloway
Thanks, I'll check that out. :leicht_lächelndes_Gesicht:
Nachricht 7 von 15
@markcalloway
The File is about 120Mb. It was the smallest one I had.
https://www.dropbox.com/s/5fu4m3omhvnqvfu/File_IFC.ifc?dl=0
I've tried both Link IFC into my project, and Open IFC. Same problem.
Nachricht 8 von 15
Update:
I opened the Revit Setupfile to see if i missed something. All was installed.
Also, I could open the IFC files on my colleges computer with Revit 2017.1.
Nachricht 9 von 15
markcalloway
Hi @Anonymous
The IFC was slow to open as expected but it opened fine on my copy of Revit 2018.
All I did was go to file, expanded open, open IFC.
I selected the IFC file and went with the default options.
See screenshot attached.
Nachricht 10 von 15
SOLVED.
@markcalloway
So, Revit wanted to use the Structural template, as show in the screenshot above.
I thought there might be a way to change the template Revit uses to Create IFC files, and i found that in IFC Options.
Nachricht 11 von 15
markcalloway
Sounds like it might be an issue with your Revit 2018.
You could look at reinstalling Revit or just use another computer to convert the IFC to RVT files if you only have 10 to do?
If you have Revit 2017 installed on your computer you could test that, or install revit 2017 and see if its only 2018 that has this issue on your computer?
Nachricht 12 von 15
markcalloway
Ah so simple, glad you have found the issue.
Don't forget to mark your answer as the solution so other people having the same issue can easily see how you resolved it :leicht_lächelndes_Gesicht:
Nachricht 13 von 15
@markcalloway
Hehe.
Yeah, really simple issue this time.
Thanks for the help.
//Filip
Nachricht 14 von 15
Viveka_CD
Hi @Anonymous
Glad to hear that your issue is resolved. However, I wanted to share the following information with you, hope you find this helpful!
Can you confirm if you have the IFC 2018 installed on your machine? See HERE
When working with IFC files in Revit, the first step should be installing the latest version of the plugin which can be downloaded here: https://sourceforge.net/projects/ifcexporter/ or through the Autodesk AppStore http://apps.autodesk.com
Before linking an IFC file, click Open (IFC Options) and use the Import IFC Options dialog to do the following:
  • Select a template to use for IFC files.
  • Download a IFC template HERE (Look under Revit instructions and samples) - IFC to get metric templates
  • Load an IFC class mapping file or manually assign Revit categories to IFC classes and types.
  • Make sure the IFC file contains the geometric data needed for the Revit capability that you plan to use. For more information, see About Imported Geometry.
  • Click HERE for more information
  • Open (IFC ) The Open Dialog offers some options which can help handle IFC Files in Revit:
Please mark this response as "Accept as Solution" if it answers your question to help others seeking similar solutions. Kudos gladly accepted.
Nachricht 15 von 15
als Antwort auf: Viveka_CD
Hi @Viveka_CD
I do have IFC 2018 installed.
However, I've always opened up IFC Files without choosing a template. This time, there were no default template loaded in the IFC Options menu.
