Cannot get rid from that lines seperating 2 walls
danezeq
danezeq
the 2 wall are aligned to the same plane, they made from the same material and ofcourse joined. it's just 2 different families.
How can i get rid of the line between them?
the elevation look terible, loaded with lines.
Accepted solutions (3)
Sahay_R
In the Modify tab, click on the Linework tool. Select Invisible Line and click on the lines that you don't want to see. They will disappear.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
danezeq
Thank you.
This methood works well per view. is there any way to cancel those line on geometry? (meaning i wont see them on all views)
danezeq
Some of the lines are going invisible and some are staying no matter how many times i click over them.
any ideas?
https://www.youtube.com/watch?v=DcSvwA9L46I
Sahay_R
In that case, I would use the Join command to join both walls.
Rina Sahay
danezeq
yep that helps sometimes
but i found the main problem in the specific example: DESGIN OPTIONS! some of the elements i clicked on are belong to a design option.
if anyone have this problem in the future....
