Cannot cut joined elements error
9 REPLIES 9
Message 1 of 10
salmanjavaid2000
1385 Views, 9 Replies
Hi everyone
I am joining a Column and a wall. And every time, I click on join, the error appears that Cannot cut joined elements. Visually, the walls are not cut by the columns. Why is this problem happening? Is there a solution to this?
Tags (2)
9 REPLIES 9
Message 2 of 10
in reply to: salmanjavaid2000
Try Join Geometry and Switch Join Order.
Message 3 of 10
salmanjavaid2000
in reply to: ToanDN
Still the same issue
Message 4 of 10
you can try this
  1. Duplicate the wall element.
  2. Delete the original.
  3. Join the copy of the wall and column.
or
https://forum.dynamobim.com/t/auto-join-walls-and-columns/1938?page=2
Message 5 of 10
RDAOU
@salmanjavaid2000
What kind of warning do you have for that wall...copy wall and column to clipboard and past in a blank .rvt which you can post here for checking
Message 6 of 10
Both of these are not working. It gives the same error again and again. I just splitted up the walls and clear the way for columns
Message 7 of 10
salmanjavaid2000
in reply to: RDAOU
Oh sorry. I just use an alternate way to get rid of this problem. Didn't notice this warning
Message 8 of 10
RDAOU
@salmanjavaid2000
If your issue has been solved (one way or the other), post the method and/or accept solution
Message 9 of 10
I don't have any issue joining a wall and a structural column.
Message 10 of 10
salmanjavaid2000
in reply to: ToanDN
I dont know why it was happening. Might be some other issue which was causing it
